Re: pull boxes
sparkmantoo
The code address's this a couple of times that I can think of, 2002 NEC 250.92(B) bonding at services and 250.97 Bonding over 250 volts.
If the pull box was for a 480 volt branch circuit or feeder and you where coming in and out with metal raceway through concentric knock outs you would have to use bonding bushings with bonding jumpers to the box.
Most of the job specs we get require a grounding conductor, many times even though we put a pull box in to meet code we pull straight through it so we do not add a jumper there, but the ground conductor is terminated at the start and finish.
[ March 30, 2003, 08:17 AM: Message edited by: iwire ]
