kcaj
- Syosset, NY
Any problem with having a light with a pull chain over a sink in a bathroom?
ryan_618 said:Take a look at 210.70(A)(1) and its exception.
I disagree. What the code requires is a ?wall switch controlled lighting outlet.? The luminaire itself is not an outlet. The outlet is the box within the wall, the box to which the luminaire is mounted. So it would not matter if the luminaire has a switch built into it; the wires coming into the box must be controlled by a wall switch.roger3829 said:If the fixture is mounted to the wall, then the switch is wall mounted as well, so it wouldn't be a violation.
