roach1521
- Deptford nj
Are pull down attic stairs considered "permanent stairs or ladders"
I do not consider trusses to be floor joists if there is no flooring or sub-flooring installed but that is just how I would argue the point knowing that it is a long shot. Some assumptions were made in creating this response...Are pull down attic stairs considered "permanent stairs or ladders"
Don't laugh. I have heard arguments that are close to that silly made here before.
If the pull down is defined as permanent, do we need to install three way switches at the top and bottom of the stairwell when pulled down:huh:
I say no.If the pull down is defined as permanent, do we need to install three way switches at the top and bottom of the stairwell when pulled down:huh:
How bout 20.5? Close enough, eh?
This is a free country and if you have an IQ of over 21 you are allowed to vote and have an opinion.
I am working on a house that was moved from one place to another, they just finished setting it in it's new place today, does that make it a mobile home now?The term is not defined in the NEC so it means whatever whomever is interpreting it thinks it means.
I would suggest any reasonable definition of the word permanent would include a pull down stair that is secured in place, unless one argues that a house is not permanent because it will eventually be torn down. Don't laugh. I have heard argument that are close to that silly made here before.
