brother
Got another vandalism job a buddy of mine working on, while im working on seperate one. More vandals have cut and stole wire and copper. Hes asking arent they suppose to pull the meter at the service to kill power inside since the vandals had cut and and took the copper at the service panel per nfp 70e since the top of buss is still hot. They at least shut the breaker off, but the panel still has power.
He says their foremen claims they need it on to 'test' things. But it will be a while before they get to the point of testing everything because of re installing wire and and runs and testing the runs in the field. I know we all have worked on the panels with the top feed still hot, but technically unless we are testing for voltage, amps etc.. it should be off in my opinion.
What do you think?
What do you think?
