Pulling 13@#8 wire
JustCallBen
San Diego
Building contractor
I have a job coming up where we need to pull 13 #8 conductors through 2" PVC conduit. Total run is about 90 feet with 3 90s. I can and will add pull boxes at critical junctions based on best advice.
Basically we go from the end point up 10 feet, 90 turn, pull 55 feet, 90 turn, pull 16 feet, 90 turn, 5 feet into control center. Wire will be cut into 13-100' rolls.
What tools other than lube and pull rope would be needed to get this done? I have a 12v winch I can use as well.
Best tool you can use is to use an electrician.
With that said.
I am closing this thread in accordance with the Forum Rules.
This site is designed for:
  • Electrical Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
