Pulling cable through conduit - 3 Cu vs 1 Al
68Malibu383
Raleigh, NC
Getting ready to run cable through 2" conduit from my home to my shop - about 100 feet total. I need 90 amps of service to the sub panel in the shop. The conduit has a few 45 degree bends (had to go around septic stuff) plus the two 90s at either end.
I would rather use copper wire over aluminum anyway and I assume a #3 Cu would be easier to run than the fatter #1 Al but thought I ask just in case. Also, can I put grease or petroleum jelly on the cable to help it pass?
I would use integrated gas spacer cable for this.
The aluminum will pull a little easier due to the weight of the wire. Although the newer copper THHN/THWN Sim-pull cable that is pre-lubed will pull easier than the aluminum. If you use lubricant use one that is specific to electrical cable. Any other lube may degrade the insulation.
Sorry, can't leave this open because:
In accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
