frank allen
is there any where in the code book that tell me that i have to install pulling C's or boxes after so may feet of conduit run and if so where can i find it?
It is not in the code. You are limited to 360 degree of bends. It may be wise to add boxes, etc for convience of pull and to not overstress wires on long pulls.frank allen said:is there any where in the code book that tell me that i have to install pulling C's or boxes after so may feet of conduit run and if so where can i find it?
ultramegabob said:just dont have conduit runs longer than your fishtape, unless you plan on sucking or blowing a string in.
76nemo said:Call me green, but I have never seen anyone blow string. Keep in mind I almost always pull in with existings, but I have never seen it blown:roll:
ultramegabob said:my favorite method is t just use a shop-vac and a piece of plastic bag and just suck it through. I keep a small shop vac in the truck, and plastic bags are always laying around.
ultramegabob said:another method of blowing in a string is to use a one shot mouse, it is a coil of string that has a small sponge on the end of it the diam of the pipe you are blowing through, you can blow it through with a normal air compressor, it unwinds the string as it is blown through the conduit. my favorite method is t just use a shop-vac and a piece of plastic bag and just suck it through. I keep a small shop vac in the truck, and plastic bags are always laying around.
It's been a while since I have had to buy any new foam mice. I got a packet of 1/2" one's the other day, and I was surprised to see they were about 50 bucks for the pack!SiddMartin said:I do the same, dont need any fancy mouses
mdshunk said:It's been a while since I have had to buy any new foam mice. I got a packet of 1/2" one's the other day, and I was surprised to see they were about 50 bucks for the pack!
