question on pulling tensions if:
Tm = .008 x n x CM
(applies to both certian conductors)
Tm = maximum allowable tension in lbs.
n = number of conductors in cable (assumes equal tension in each conductor)
CM = circular mil area of each conductor.
my question is if you have conductors of different sizes? if you had multiple 350kcmil cables and a single 1/0 conductor would the CM be equal to circular mill area of the sum of the cables? Or would this method potentially place to much tension on the smaller conductor?
Tm = .008 x n x CM
