Greg H
- Durham, NC, USA
- Electrician
Had a job the other day where a customer wanted me to install a single GFCI receptacle. It was a sight unseen job for a customer that I had worked for before, so, I was billing on a time and material basis. Simple enough in theory, but when I got there and started investigating turns out the wall that they had initially wanted the receptacle in was filled with spray foam. I found this out by doing a wire probe test of the area they wanted, so, I didn't do any significant damage to the wall; but it also felt like there was some kind of blocking in the wall as well (lesson there: always do a wire probe test before making cuts in a wall that you didn't rough in yourself, and even if you did, still not a bad idea). Fortunately, there was an adjacent interior wall with hollow wall cavities and I was able to convince the customer that that would be a better location for the receptacle, so, it didn't end up being a problem, customer just has to spackle and paint over the probing holes that I made.
However, been thinking about what I could have done had there not been an equally suitable empty wall cavity nearby. Has anybody figured a good (read: economical) way to pull wire through existing spray foamed walls? The only two ideas that I have thought of wold be cutting out a pretty big panel(s) of sheetrock and carving a big enough notch in the foam to bring my wire through or using a flexible drill adapter to try in bore a channel in the foam, but neither of these seem like particularly good ideas for a number of reasons (time, risk of damaging anything else that is in the wall, compromising the thermal properties of the spray foam, customer will have to repair a lot of sheetrock, I could go on). Has anybody figured any good tricks for this? Thanks
