hmspe
- Temple, TX
- PE
I have a project where I called out upgrading an existing meter/pullout in a Square D "three pack" from 100 amps to 200 amps. The meter base was already rated 200 amps. The pullout is Boltswitch and I have no issues there. The issue is with the conductors between the meter base and the pullout. My notes required use of Square D parts. The contractor field wired. The inspector has withheld approval.
Is field wiring like this typical and acceptable? I'm being asked to approve the installation.
