chevyx92
- VA BCH, VA
What are the advantages to using a pulse start metal halide fixture over a regular metal halide? Why are they used?
Jljohnson said:Advantages are as Sidd pointed out, disadvantages in my part of the country is only one of the 8 wholesale houses in this area even stock a small amount of replacement lamps and ballasts for the pulse start fixtures. seems the service call always turns into a special order thing when it involves a pulse start MH.
Wonder why that is if as others said they are efficient? I personally don't see how they are more efficient than regular MH.Pete Benoit said:As of 3/31/08 we will no longer be able to install probe start MH in a 150 thru 500 watt vert. lamp fixture in NY under title 19 I think they have followed california on this.I have heard that its a matter of time before replacement ballasts and lamps will no longer be avail.
chevyx92 said:Wonder why that is if as others said they are efficient? I personally don't see how they are more efficient than regular MH.
Yes he did.SiddMartin said:he said PROBE, not pulse
SiddMartin said:How Does Pulse-Start Metal Halide Lighting Save Money?
Compared with probe-start lighting, pulse-start metal halide lighting saves you money in four ways:
Brighter light ? Pulse-start lamps produce more mean lumens per watt of electricity.
Lamp light output is maintained ? Because the light output of lamps declines as they age, the design of the lighting system must be based on the ?maintained? or end-of-life light output. The bigger the decline (lumen depreciation), the more excess-initial-lighting must be provided. Pulse-start metal halide lamps are about 6 percent better than probe-start lamps in maintaining light output over their service life, so fewer lamps are required.
Lamp life is long ? Some pulse-start metal halide lamps last longer than probe-start lamps. For example, 250-W pulse-start lamp can have a 15 000-hour life, compared with a 10 000-hour life for a probe-start lamp of the same wattage.
Lamp replacement is less frequent ? Replacing burned out lamps is a significant labour cost. Pulse-start lamps last longer, so they don't need replacing as often, thus lowering labour costs.
Huh? Do they look like an empty sheetrock mud bucket?SiddMartin said:kinda like the waterless urinals that are poppin up now
mdshunk said:Huh? Do they look like an empty sheetrock mud bucket?
