Electromatic
- Virginia
- Master Electrician
I'm about to wire another new submersible pump with a seal fail electrode. This is the kind where there is only a single wire in the control cable for the electrode. I understand I will need a seal fail relay similar to this: https://cdn.automationdirect.com/static/specs/psfrrelays.pdf
My question is, what do I land on the "Com" (common) terminal of the relay. I think the other side of the electrode is connected to the pump chassis. Would I land the pump ground wire or at least a ground wire from the control panel terminals to this Com terminal?
