Purchasing
mglennon
Does anyone know of any technology available that would allow foremen to order material in the field electronically and avoid having to call in orders over the phone?
Re: Purchasing
Most jobsites have fax machines.
We usually fax orders in, it is more accurate also. We don't get the "I thought you said L6 20R..."
Re: Purchasing
I read on another forum about a guy that has got his truck outfitted with a laptop equipped with a GPS navigation system, software that connects his laptop to his cel to enable faxing directly from the van and a portable printer.
Sounds like a nice mobile office set-up that pretty much allows you to do all bidding, ordering and any other communication necessary to run your business without leaving the truck.
A customer could be impressed when you take a look at their job tell them they will have a proposal by the end of the day, then go out to the truck and 5 minutes later their fax machine is printing out a proposal from you.
Re: Purchasing
You should be able to do what you are needing with a Black Barry and email the order to your supplier.
