AdaptnConquer
- Bayou State
This is gonna be long so bear with me please. I need help with changing this panel. It is a 100 amp Bulldog Pushmatic. But it starts at the switch box next to the meter pan. It looks ok but I never had a fused switch box next to the meter pan.
Now from there it goes through the wall to the Pushmatic in the garage. Its a 100 amp with side by side breakers 14 in all.
30/30
50/50This one has been tripping when oven is on.
50/50
20/20
20/20
20/20
15/15
Now for the inside. Basically almost everything in the house is supposedly is run from this panel for a 1700sq ft. house. Almost seems impossible, electric stove, water heater, lights, fans, T.V.'s.
Now when the stove is on and most burners or the oven is on just that one breaker will trip. When I push it back in it still shows off. Now for the other problems. Some of the neutrals appear to be melting.
Then the last 50 amp breakers have a piggyback that goes from the buss to the breaker along with the wires leading off somewhere. So to my understanding basically they are bypassing the breaker or are they running 220 off a 120 breaker?
Then there is another issue. If you look to the right of this photo, you'll see some wires piggy backing off the lugs going to another breaker box, a 125 amp box.
And unfortunately that box feeds another box that was added on for the "Sun Room". I haven't been able to see that box till tomm when they move some stuff for me to get to it. I know that this breaker box is running out of the 125 amp box on a 60 amp Double Pole.
Sorry it was so long. I just wanted you to know what I know so far. I know there are several things I can do. I just want to hear from some of you experts out there and make sure I do the right thing. Please help! I'm suppose to start working on this tomorrow.
30/30
50/50
20/20
20/20
20/20
15/15
