- Chapel Hill, NC
- Retired Electrical Contractor
I read this to mean that any box smaller than 2 7/8" x 1 3/4" would follow the exception. The exception states that all conditions must be met.
I have a door jamb box( for a jamb switch) that is 2 5/8" x 1 1/4". I have never seen them in metal. Could this mean that metal door jamb switches are not allowed assuming they all are smaller than 2 7/8" x 1 3/4"
314.29(A)(1) Boxes 1650 cm3 (100 in.3) or Less in Size.
The openings in the building surfaces, if reduced from the outer walls of the box, shall be centered not more than 25 mm (1 in.) from the centerline of the box, and shall not extend beyond the walls of the box. If rectangular, the opening shall be not less than 73 mm (2 7⁄8 in.) by 45 mm (1 3⁄4 in.) in size. If circular, the opening shall not be less than 90 mm (31⁄2 in.) in diameter.
Exception:
Smaller openings in building surfaces that accommodate one or more individual devices shall be permitted if all of the following conditions are met:
- (1)
The outlet box that supplies the device(s) is nonmetallic.- (2)
The branch circuit wiring that supplies each device consists of a separate nonmetallic cable assembly originating outside the box, or individual sets of conductors in a single nonmetallic raceway, all of which originate outside the box. Other than the connections to a single device, these conductors are not spliced in the box or continued to another device, and no other wiring or raceways enter the box.- (3)
Each device is capable of removal from the building surface opening without being damaged. If a special tool is required for this purpose, the applicable circuit directory for the device records the location of the tool, together with a product code/QR code for acquiring a replacement if necessary.- (4)
All connections for each device to the branch circuit wiring are made with listed clamping-type wire connectors, which are supplied with the devices. The branch-circuit conductors are arranged to permit the connector(s) to be exposed after the device has been fully removed.- (5)
The device assemblies are listed for this application.
