We have a PV System with 6 strings of Enphase microinverters connected to a 208v/Ph combiner panel with a 150a main breaker, this panel connects to a fused AC disconnect fused at 80a. Then this connects to an 80a back feed breaker in the main 400a panel. Max system AC current is 63a at 208v/3Ph. The electrical contractor is saying we need to change the 150 main breaker in the combiner panel due to this being against code. Has not said what code. It is my understanding that this 150a main breaker does not need to be changed. It is mearly a 150a rated switch to shut down all 6 strings at once. Thoughts?
