I know these grounding issues are a hot topic over here at the Mike Holt forums. I'm listening to a PV training put on by IREC (http://www.pvonlinetraining.org/) which is stating that if no grounding electrode (building steel, other ground rod, etc) is withing 6ft of some part of a solar array, you have to drive a second rod. They're basically saying that all pole mounted arrays must have auxiliary ground rods because they are inevitably over 6ft from the building's grounding electrode. My understanding was that you COULD drive an auxiliary electrode per 690.47(3)(D), but that its generally not recommended for safety reasons.
Does anyone know where this 6ft rule is found in the NEC, and why wouldn't you be able to just create a path from the array to an existing EGC which leads back to the home's existing AC ground rod?
