I have an inverter that is single phase at 240/120 volts on the AC side of the inverter. I am wanting to use the inverter for training purposes. The only house power that I have available is 208/120 volts. Will it be permissible to use single phase 208 volts to supply the inverter for the house power. Again, this will be for training purposes only. The tech support from the inverter company said that it would be ok. I was just wondering if anyone had any suggestions. I am sure that I can use a transformer but if I don't need to use it then I would have that much less weight on my trainer. At the same time, I don't want to have a smoke test with it either. Thanks
