Jim W in Tampa
- Tampa Florida
Is it legal to cut a 90 in half to make a 45 ? And if it is would anyone call this a smart move ?
I've done this Jim and I do not recomend it. Very hard to keep the coupling on and harder to get it on.Jim W in Tampa said:Is it legal to cut a 90 in half to make a 45 ? And if it is would anyone call this a smart move ?
Jim W in Tampa said:Chalk it up to poor planning.
Any relation to the Seven Dwarfs?celtic said:Do you know the "6 P's"?
paul said:Would that be, 'Proper Planning Prevents Piss-Poor Performance?'
(D) Wet Locations. In portions of dairies, laundries, canneries, or other wet locations and in locations where walls are frequently washed, the entire conduit system including boxes and fittings used therewith shall be installed and equipped so as to prevent water from entering the conduit.
Cavie said:IF you have lots of glue on hand, and are in a real bind, dig a ditch, pour the glue in the bottom and light it. now you have in inground heater. Don't laugh, it does work. Ever cut pvc with nylon string???
