The outside diameter of the PVC coated rigid is larger than the uncoated.
There are special bender shoes for some benders, but you should be able to use the next size larger of the standard shoes.
The threading is different.
If you are using a handheld threader like a Ridgid 700 with the 12-r dies, then you will need special dies that have the hole bored out a little larger to clear the coating.
If you are using a threading machine like a Ridgid 300 you don't need to change anything if you don't want to. Ridgid makes special jaws to hold the coated pipe but the knurled ones work.
You might have to fix damaged coating sometimes.
I used to smooth it out with a knife and then wrap with some tape and then spray with some PVC coating that you can get from the conduit manufacturer.
