N_Jay
New User
- Kannapolis, NC
- Consultant, Radio Engineer
I am building a garage/workshop and will be using PVC conduit.
The walls will remain unfinished, and being a metal tube building the conduit will be mounted to the tubes (Horizontal runs mostly above the 8' level.
If all the junction, switch, and outlet boxes are mounted, and the conduit is properly supported between boxes, does it need to be glued?
P.S. Although this is a DIY project, I hope you don't mind helping with an answer.
As a Radio Communications engineer I occasionally deal with codes, but this stuff get left to the contractors.
Thanks in advance.
Neil
Thanks in advance.
Neil
