PVC Conduit in basement
ivsenroute
Florida
I am seeing more and more unfinished basement with PVC conduit running down the cinder or concrete walls with NM cable visible entering at the top to feed down to a metal box mounted on the wall and the NM cable covering is visible where it enters the box.
I always thought that there has to be a transition at the top of the PVC where the NM enters and then at the box there is no place for the NM to be "connected" to the box with a strain relief or internal clamp.
Now that I read the NEC, I don't see where this is a problem.
How do you see it?
charlie
Indianapolis
334.15(C) In Unfinished Basements and Crawl Spaces. . . NM cable installed on the wall of an unfinished basement shall be permitted to be installed in a listed conduit or tubing or shall be protected in accordance with 300.4. Conduit or tubing shall be provided with a suitable insulating bushing or adapter at the point the cable enters the raceway. . .
Sorry, you are required to have something to protect the cable. Also, read the rest of this section. :grin:
ivsenroute
Florida
Yes, I was aware of the bushing where it enters but I am more concerned about the fact that there is no way to attach where it enters the receptacle box. But then again a strain relief bushing was never needed for individual wires in conduit anyway.
C3PO
Tennessee
I run PVC down block walls into PVC FS boxes all the time here with no bushings at the top. Why would you need a bushing to protect NM cable from PVC conduit? I could see protecting it from EMT or something with sharp edges. (Just my stupid opinion.)
peter d
New England
C3PO said:
It is not enforced that way here with PVC anyway.
What do you all do in this situation?
I don't use PVC for wall receptacles in a basement, but if i did I would use a TA with a plastic bushing on it.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
We just put a pvc coupling on the top. You could use a connector with a bushing but a coupling is rounded and smooth that it is accepted here.
