Christoph
Master Electrician, Code Official
- Coopersburg, PA
- Electrical Inspector
Hi
I am bidding a remodel of a prominent Fast Food Chain Restaurant and was wondering if someone had any opinion on if there is the need for RIGID in the area of the drive through / underground portion, coming out of a pull box at the cashiers window, there are a bunch of 3/4 to 2" conduits called for and the difference between PVC and rigid is $6k.
So far i have determined PVC to be acceptable in the Uses permitted section of the code, I am just making sure there is no other thing I am missing e.g. areas with traffic etc. roadways.
Thank you
Thank you
so unless they are completely demo’ing the D/T concrete, you’re coming up the back wall with all this conduit. Even if they do tear it out, which I’ve never seen them do, you’re not getting those conduits up that footer. They’ll likely tear out just in front of the windows for new loop detectors, and you’ll have to drill through the wall and footer to get out. They’ll have to replace the base tile there because you can’t get the angle on the wall to get through; you’ve got to go at the very base of the floor. And do it to the side of the window because the P..OS guys have to be able to fish down to that and connect it.
