bensonelectric
Why is it that electrical PVC conduit almost never seems to keep out leaks, when plumbing PVC (Sch 40) can prove able to hold in pressures of 150+ PSI?
I only ask this because I had to dig up some conduit the other day, and when I finally got it out of the ground the whole thing was filled with water. I asked the guy who installed it, and he said he glued each joint, and even twisted the pipe a 1/4 turn after inserting according to the directions. I wouldn't be so concerned if it wasn't for the fact that I just built a pneumatic air cannon out of 2" Sch 40 PVC, and it holds a pressure of 150PSI without a problem. The only difference I could see was that I used primer, and he had not, so is primer really worth the extra effort when doing PVC conduit jobs?
