Re: pvc conduit
While most PVC comes out of the same factory's there is a difference in glues is one step and two step, one requires a cleaner to be use to pre-activate the PVC before the glue is used and the other does not need it. The glue that Carlon has at the supply houses is just a one step PVC activator and glue all in one. The plumber inspectors around here require a two step cleaner/glue with a purple dye in it to let them know that the cleaner has been used.
But as far as the NEC goes I think it has to be listed for the purpose as the fittings has to be listed. Could we call the cement part of a fitting?
