Hi Mike
Is it allowed by NEC (or any other code) to run electrical PVC conduits in Bathroom and Kitchen Floors (wet areas). If yes, please provide reference of NEC or any other codes and if possible, the installation method too.
Regards,
Hatim
This doesn't seem to be exposed to me. I don't see a problem.They laid the PVC conduits inside the floor, which will be covered with ceramic tiles. . .
They laid the pvc conduits inside the floor, which will be covered with ceramic tiles....
This is purely residential building and they ran the pvc electrical conduits inside the floor of kitchens/bathrooms (the civil folks did the waterproofing of kitchen and bathroom as well). I just wanna make sure if it is allowed to run PVC electrical conduits in the floor and do we have to use different kind of cable/pvc electrical conduit in this situation.
If the run is actually a service raceway, there is a major problem with 230.6, "Conductors shall be considered outside of a building or other structure under any of the following conditions:Are these service conduits . . .
Are these service conduits or is this thread headed in the wrong direction? In or under the concrete slab, does it matter either way?
Someone ran PVC within a concrete slab, is it more complicated than that?![]()
Although the OP doesn't mention whether or not it's the service, I'd assume by the wording of the question he's referring to branch circuits as he specifies the kitchen and bathroom.
It's exceedingly rare to have a kitchen and bath side-by-side (some codes prohibit it), so I'd say these are branch circuits. If it were the service, this means there's no basement, so where in a dwelling is the panel normally located if there's no basement? I'm just having a hard time envisioning a dwelling on a slab and having the service go under just the kitchen and a bath and have a logical location for the panel inside the house.
Charlie & Rob,
Please don't cry, I'm sure he meant you as well.![]()
