PVC Conduits in Dry wall partitions
Sajid khan
Pakistan
Hi All,
Can anyone help me identify if it would be a problem if we use PVC conduit in drywall partitions in a hospital project? This will save us a cost compared to EMT Conduit. Will it be against the NEC rule? What could be the implications?
Regards
Hi All,
Regards
Take a look at 517.13 (A) and 517.10 (B).
I did not look at sections mentioned in post 2, but presuming that was addressing patient care circuits that require a wiring method that in itself qualifies as an EGC. PVC can not be used on said circuits because it doe not qualify as an EGC.
Also should you have a place of assembly within the facility you couldn't use PVC methods within that location either. Outside those two applications probably fine.
To qualify 517.13(A), can we use a separate Grounding conductor? or it shall necessarily be an EMT?
Art 517 requires a grounding conductor in a 250.118 metal raceway or cable.
Two wire type conductors are not an acceptable means.
A second EGC does not comply with the wording. The raceway or cable system used shall in itself qualify as an EGC as well as contain a conductor type EGC.
You cannot use a separate or second equipment grounding conductor. The wiring method itself must be an equipment grounding conductor and must also contain an equipment grounding conductor of the wire type.
