PVC connectors ok for Sealtite ?
jsc
New member
Is it ok to use PVC connectors on the ends of sealtite instead of sealite connectors? 1/2" sealite glues nicely in 1/2" PVC connectors and couplings. I could not find anything in the code.
Thanks for your help.
Re: PVC connectors ok for Sealtite ?
No, see 350.6
I was wondering how many others have noticed how well this works. Not that I would do it of course. :roll:
Pool workers love to do this! I have seen it in almost every pool installation that I've worked on. They'll install a $1300 chlorine generator and be too cheap to buy the proper connectors! Pool cleaners should not be doing electrical work , IMHO
Mike
used it also on 3/4" pvc couplings to 3/4 sealtite. But only in a emergency then came back with the proper fitting and r/r it
But it fits nicely.
Aside from the code violation and from a practical point of view, if you're using "seal-tight" it has a metal core which needs to be properly grounded. If you use the proper seal-tight connector, the metal piece that threads into the core is designed to complete the grounding system when it comes in contact with the other part of the connector. Whereas, using the PVC connector won't accomplish that. If you're using Carlon flexible PVC, while it doesn't have a metal core, the proper connector threads into the end and secures the fitting to the flex and won't come apart. Using a PVC connector on this might not last if it's bumped or reconnected after replacing a pool motor.
Now, on the subject of pool guys doing electrical work, this was obviously an installation that was not inspected. If it was, the way I see it is that you have 2 choices : 1) issue a license to the pool guys so that they can do electrical work for pools or 2) report the incident to the building dept. and have them fined for doing the work. From my point of view, I worked hard to get my license and even harder to maintain it. Having someone out there doing shoddy work and undermining our area of expertise is unacceptable.
Sorry - didn't mean to get up on the soap box.
