Re: PVC expansion fittings
Here is another aspect of PVC installation:
A contactor was installing underground runs of 2" PVC. It was a hot day (80's), well hot for the Pacific NW. The PVC was strung out on the edge of the ditch, then installed and backfilled. The cooler earth (52 deg F) caused the PVC to contract and pull apart at the joints. Since this was a government job, the PVC had to be dug up every 20 ft and repaired at the joints.
In my opinon, PVC should never be run on the exterior of a building, its OK for service going up to a weatherhead where it can move away from the meter. Now that we have at least two manufacturers with listed raintight EMT fittings, EMT would be a preferred alternative.
