PVC expansion fittings
BMH
Can 3/4" PVC expansion fitting be poured in an slab on metal deck at an expansion between 2 decks?
The ones I have seen might not work. How ever if they are listed by the manufacture, suitable to be encased in concrete then yes.
Is the part that allows for movement sealed, so as to not get concrete all over it.
You may not be using an off the shelf PVC expansion fitting, the proper expansion fitting should be described on the plans, contact the engineer on the project, and ask for a detail of the fitting.
