In reading the code in regard to expansion joints in pvc conduit it says that in a straight run between securely mounted items you have to compensate for expansion. I have a run approx. 40' along the exterior wall of a building.I will have a 90deg elbow on each end,one will terminate in the meter base the other will LB into the wall and enter the back of the interior load center. Does this install require an expansion fitting. Have always used EMT and never been concerned or needed to know what constitutes the use of an expansion fitting. Thanks.
