goingtohurt
I build Modular homes I need a way to easily install the Feeders into the panel from the meter main after the house is assembled I thought pvc? There was a question of not being able to ground the PVC. Is this legal?
Mike are you sure about that?Originally posted by jwelectric:
These homes that you are building, at least in my state, will require a third party listing as well as a HUD stamp.
Do what I can to help.Originally posted by goingtohurt:
I realize that it is very hard to ground PVC. Thanks for the first year cubby joke.
How will you clamp the SER to the panel for strain relief? Otherwise, doesn't sound like a bad idea.It was my idea to leave a # 12 from the panel to the crawler until the assembly and use the 12 as a pull string so to speak pulling the feeder in and it would be as if I had done it on site.
How? I'm curious (not so much "doubting you").I do know the exact location on every house...
they would ??While many would install SER cable into that conduit
550.33 Feeder
(A) Feeder Conductors Feeder conductors shall consist of either a listed cord, factory installed in accordance with 550.10(B), or a permanently installed feeder consisting of four insulated, color-coded conductors that shall be identified by the factory or field marking of the conductors in compliance with 310.12. Equipment grounding conductors shall not be identified by stripping the insulation.
The would and do! Because of the differences between mobile (subject to article 550) and Modular (not subject to said article), many of my competitors routinely use SER cable for their connection.quote: While many would install SER cable into that conduit
they would ??
From NEC 550.2 Definitions:Better recheck 550!!! Manufactured (modular)Homes are included in Article 550
No argument here. But there are not that many rules per se, that set the modular homes apart from any other house.OK, Then your talking 545,Manufactured Buildings,they have quiet a few rules of their own also.
