Sch.80 PVC
Sch.80 PVC
My experience with using this product in any exterior surface mount situation is not good and its application envelope is definitely limited.
It is especially intolerant of strong sunlight such as experienced at altitude in the Mountains. IN these cases it tends to warp, sometimes fracturing and it discolors quickly. Larger sizes seem to have a bit more stability, but even then our preferred method is only to use it for underground and then transize above ground level as quickly as possible.
Generally more anchor points are desirable, but direct sunlight can make it go over the edge.
Also 80 may be worse than 40 in this regard.
