slc410
- Madison wi
- Electrician
I'm wondering about a 2" conduit I ran for a panel feeder from a main disconnect located outdoors to a sub panel located indoors for a business. The run starts at the outdoor disconnect then transfers to EMT indoors. The EMT ends in the sub panel through a non concentric opening that I cut out myself. The conduit contains an equipment grounding conductor to the sub panel. My thought is I would not need a bonding bushing because it does not terminate in a concentric/eccentric knockout. Would like to get opinions and code articles pertaining to my installation. Thank you.
