If running PVC underground I believe it has to be 18 inches below finish grade. What if it is comming out of a building (a hospital perhaps) 12 inches below grade right at the outside wall. Can the PVC then be offset to 18 inches below grade and still be within NEC? The total run would be 18 inches below grade except for about 2 feet of the pipe where it offsets down.
Thanks in advance!
Thanks in advance!
