PVC
roger
Fl
Retired Electrician
Re: PVC
Nico, is this an exam question? In any case this is in covered in chapter 9 and annex C
Roger
tom baker
Bremerton, Washington
Master Electrician
Re: PVC
Must be exam time. Sure are a lot of these questions.
However, the question is incomplete. Nico, what type conductor (its not wire or # in the 2002 NEC)?
daveselectric
Ohio
Re: PVC
You will also need to factor in derating for more than three current carrying conductors. You should also look at the length of the run to consider any voltage drops and the possible need to increase the conductor size.
