jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
Went with a friend the other day to check out some damage and saw a QO panel with both breakers & fuse blocks in it. SP fuse block is a QO breaker housing with slot for a small cartridge fuse. Never saw this before, but I assume Square D had been making this panel a while and these fuse blocks, then designed the QO breaker to fit the same panel? My friend had never seen it either, never heard of it. Panel also had several DP tandem fuse blocks and a SP tandem fuse block. Had 1 std QO 120 breaker in same panel.
How cool is that? Designed that in some cases a breaker could replace the fuse block. Anyone else ever seen these?
