I have a customer that's considering updating one room in the plant to Class I Division II and wants me to give him a cost estimate. As of now he has EMT conduit with set screw fittings and normal J boxes with knockouts, etc. I have a few questions.
Does all of the conduit need to be changed to IMC or RGS with threaded couplings?
Do the boxes need to be changed from the regular steel J boxes?
There are a couple GFCI receptacles that are flush mounted in nail on boxes inside the wall so the wiring for them is also inside the wall. I don't know if it's NM or what. Should I disconnect them and run conduit to new ones or can I leave them in place with a certain type of cover on it or....?
They have a mixer with an open blade disconnect on one of the machines which also has a couple motors mounted on it. Does that disconnect need to be rated Class I Division II? Are those motors going to be ok in this environment? I think the code book defined this area as an area with contained flammables or something so I may be going overboard with my thinking.
Any help or information would be greatly appreciated.
Thank you.
Thank you.
