I have been reading up on sizing equipment branch circuits for our shop.
I have some questions about determining whether an machine is a continuous or non-continuous load... :blink:
For example, most welders have a duty cycle, and it left on but not used, draw very little power.
So during heavy use, they still need to cool down according to their duty cycle, thus non-continuous IMHO.
If left on for long periods, they only draw a few amps of parasitic power...
So would this be a Con or Non-con?
Spot welder - can really only be operated for a few seconds at a time, can't be left on.
Cord connected devices (non-fixed) appear to be rated at a blanket 125%.
Granted, any motor draws a fair amount of power during startup, but many, once running, draw very little.
For instance, some motors drive a fairly constant and large load, say a big blower or circulator pump. Fine, those sure seem like continuous loads. So does an electric oven, or air compressor under a lot of use.
Now lets look at a 7hp 3ph table saw. Big startup load, but then very little load until you cut something. But the most you can cut is usually 8 to 16 feet or so, before you have to stop, and reposition for another cut. Kind of works out like a duty cycle. I don't see any way to continuously load that machine, short of some sort of automated feeder etc.
CNC machines - It may be possible to run these machines at near full power during some operations, but generally they have to pause slightly between passes. In addition, many have variable frequency drives, not sure if these draw power in the same manner as a normal motor, or if they're a non-linear load, or what.
Last stupid question of the day. You are supposed to calculate lighting loads based on the exterior building size and VA per square foot. But, I have a completely engineered LED lighting plan that uses a small fraction of the normal, historical power.
So do I still have to use the prescribed lighting power calculations? Any how do you apply that? Do you have to take the total requirement, divide it by the voltage to get the amps, and then divide it up into X number or circuits, even though they are very lightly loaded? For example, the LED plan calls for 14,920 watts. As best I can tell, the rating for this space is 2 VA per SF x 17,000 sf = 34,000 VA. So the LED lighting is about 44% of the calculated amount.
Thank you in advance to anyone that answers....
My brain is smoking right now..
Bryan
Bryan
