jason sleeth
- Illinois
I am teaching motor calcs and have a question. In dual voltage motors such as a 240/480 motor I was taught that the low voltage is always wired in parallel and the high voltage is always wired in series but I am not sure why? Why can't you wire the low voltage in series and the high in parallel?
If I am looking at a motor with 24 ohm windings in a nine lead motor and If apply 240 volts in a parallel config the amperage draw will be 10 amps. correct? If I wire it to 480 V in series it will draw 5A? Why can't it be wire at 480V (20A) or in parallel or 240 (2.5A) in series?
