milemaker13
- Suburbs of Chicago
Hey Gang!
I've got a question or two about the emergency lights in our warehouse. About a month ago some under floor electric was cut while pouring a new concrete pad. Long story short, I finally got around to restoring power to these EM lights.
Now with power restored, they heads are lit up constantly. I went and fiddled with them a little (ie. pressed the test button, checked battery volts and scratched my head) but cannot figure out why they don't work properly. It has now been nearly 24 hrs and they are still the same.
This particular type (we have several differant types in the building) uses (2) 6 volt, 7 amp hour batteries, incandesesent bulbs and has a small PCB and transformer for charging.
Checking voltage, I got about 7 volts (should be 12v). The unit appeared to be charging at that point because when pressing the test button the volts dropped to less that 3 volts .
So, my question: Does anybody know how these SHOULD operate? I have no instructions on this unit. I just wanted to ask you all before condeming the little PCB (and therefore the whole fixture I guess). I am going to google all I can, but I usually get very good advice right here.
OK, thanks much- I'll check back at break time
