Does anyone have a link or know off hand what would be the minimum hole (with bushing) size required when feeding 4- 2/0 aluminum XLPE RWH USE-2 wires into the main panel box and also the sub pane box in the detached garage?
I'm going to use 2-1/2" schedule 40 PVC in the trench and come out of the ground via 2-1/2" PVC schedule 80 sweeps and LB's into the outside wall but where the wires enter the buildings (as I understand it) because of the 4 wires being RWH USE-2 XLPE they don't need conduit protection indoors? If this is true, it's going to look like a bundle of 4 seperate wires... should I zip tie them together every so often until they reach the panel? I'd like to reduce the size of the hole I have to knock out of the side of the main panel box to feed the wires as it's already fairly crowded inside the box and 2-1/2" seems excessive. Also if I may ask, if I use 2-1/2" pvc through the wall (from the LB to the inside wall) should I use a bushing flush with the surface of the inside wall? Does the empty space inside the conduit where it enters the building need to be filled with some sort of fire resistant insulating material? What would be best way to run the 4 wires where the spill out of the inside wall and on to their lugs inside the panel box?
