Horseman1970
- Houston, TX
Hello everyone.. i have a question that I don't know the answer to, but i'm sure people here do.
I had an ac disconnect that went out. It was an old style (square D, model number was 2q/200, i believe.) Since it went out, i went to the Home Depot, and bought a 60 amp disconnect new one, with the plug in disconnect. I installed it, turned on the outside unit, and the ac ran fine. It was a cool day, so i let it run for about a minute, then turned it off. Now that it is warmer, what is happening is this....
I turn on the outside air unit, and it runs.. for about 10-15 minutes. Then the ac breaker in my main panel trips, and it shuts off. So today, i go look at it, and now the ac breaker in my main panel automatically shuts off.
I looked closely at my ac disconnect, and you can see where an arc occured between the copper blades and the spaces they plug in to.
What would be causing this? As you can tell, I am not an electrician and do not know what is causing this?
Any help you guys can provide would be greatly appreciated.
Thank you.
Thank you.
