pickleman
New member
 - New Jersey
Hello all, firs just to give a short rundown of the process I am trying to control. I am the maintenance manager for a pickle company and we have 6 small brine tanks (6 different flavors) that feed one machine (the same machine makes all 6 products with minor changeovers) and we overfill the containers with brine so that there is no air inside the container so we have a capture pan the captures all of the excess brine and pumps it back into the respective tank. So right now there is one pump with one float at the end of a pvc pipe and when they change flavors we just move the pipe with the float into the correct tank, it is not that I want it done. so, I recently made a small control panel to control one sump pump with float switches from each tank. I made it so that each float operates a relay which sends the power to a terminal strip which sends power to the pump. The obvious thing here is that with the terminal strip it backfeeds the power to the other relays, which I know isnt the right way to do it but there is only one selector switch to operate everything and I am using timer relays just to be safe. My question is, how can I wire it so that it does not backfeed to all of the other relays? PLC? I have to make one or two more controls panels like this for other parts of the plant and I would like to do it right and safe. Thanks in advance for any help.
