pkelectrical
- NJ
If a phase touches another phase in a 3 phase AC supply it goes bang due to them being 120 degrees apart and therefore being at different voltages when they touch (this I understand), so WHY after passing through an electrical component, can all three phases be joined onto a 0 potential wire (the neutral)? Surely they are still out of phase and should still go bang?
1. What makes them be the same phase?
2. Why by going through electrical resistance it makes the voltage "OK" to go into zero potential wire? Ex. 120 line and a load (bulb)
3. How can in wye configuration the end of winding of each phase be joined together and not go bang?
I cant understand this, and I was not able to find an answer doing research. I would appreciate if someone could give me an answer to my questions.
Thank you in advance
