JJWalecka
- New England
I am wiring a dwelling with an addition being built on to it. The existing feed is 100 amp. I would like to install a 200 amp two meter bank with two separate disconnects one for the new 100 amp panel located twenty feet from the service equipment (feeding the existing dwelling) and the other disconnect feeding a second 100 amp panel (for the addition) on the second floor, of the addition, located about thirty feet from the service equipment. The home owner said that she didn't think that you could put two meters because it was an "in law apartment".
I am new to residential installations and I'm ignorant as to the specifications for them. The disconnects would protect the conductors inside the dwellings to there corresponding panels.
My other question is that the old panel has a 8 AWG ran to the water meter, I would install a 4 AWG to it in it's place. Can I fish it through the existing dwellings ceiling above the sheet rock and then support it with staples as it enters thje addition. The dwelling doesn't have a crawl space or basement. 250.64(B) seems to tell me otherwise.
250.64 (B) Securing and protection from physical Damage
A Grounding Electrode conductor or its enclosure shall be securely fastened to the surface on which it is carried...
forgive my ignorance in the matter most of my Electrical experience is Commercial applications. I'm trying to establish my own Electrical Contracting Business. Any information would be appreciated. Thank you for your time and effort.
Justin W.
Justin W.
