We are a steel cabinet manufacturer, with some of our products UL listed. We recently had an inquiry from a potential customer. The idea is to house a pond aerator in a steel cabinet that would have an access door for maintenance. The aerator would be mounted on the steel cabinet and the aerator has a chord and would be plugged into a separate free standing weather proof GFCI outlet. Depending on the installation, the GFCI outlet comes up through the bottom of the cabinet and is housed inside the cabinet or the GFCI is housed on the outside the cabinet and the chord would pass through a knockout, with a rubber grommett.
My problem is I don't know whether this cabinet should be UL listed or not and I don't know how to treat this cabinet under the NEC, since the cabinet is housing a separate listed device that is chord connected. What I do know is that the aerator is not listed for outdoor use, so it does need a weather proof cover. I also believe that grounding this cabinet with the grounding system of the GFCI outlet would be a good practice because I could see trouble if the chord gets frayed or the steel aerator housing is energized and then energizes the steel cabinet. Without a grounding path, there could be trouble. Does anyone have any thoughts or know of specific sections in the NEC that would call for a listed cabinet here or at least spell out grounding requirements? Thanks in advance.
