Hello, and thanks for all of the help that I have been getting from everybody,
I asked and electrician at my work that I was watching work on an installation
(careful not to bother him, I do not like anybody looking over my shoulder watching
me work). He said that he was installing a transformer and that the 480 VAC 3 phase
panel that he was going to feed it from did not have a "grounding conductor" ran to
it in the conduit. He said that it was using the conduit itself as a ground. I saw that
after he was finishing up that he had ran a green wire that I am thinking is ground
from the panel ground terminal to the transformer. ????
Can you do this, because there is not a ground coming into the panel. I know that
he said that the steel conduit is the ground. I am asking for one, I do not know yes or
no and two this green colored conductor that he ran from the panel to the small
transformer went to the ground terminal that had a ground symbol on it, but then
it also when from there to a small panel that he also mounted to the wall next to
the new transformer. I am do not want to ask him too much, this is due to he does
not give out much info on electrical. I will just say that he flies off the handle quickly
and he is the only electrician that works there, so I talk to him when I get the chance.
I wrote a book here, I am learning a little each time, it is slow going/trying.
