Kyell
- Titusville Florida USA
Hello Forum,
I need help finding a reference for LFMC and an install from a disconnect to a transformer.
I have my code book out and I searching my art 350. I am installing LFMC with an internal ground wound up within it. I am using Metal LIQUID tight fittings made for this product, as I have many times before. I want to use grounding bushing at both ends. However I am being ordered to remove both my grounding bushings and my Liquid tight fitting and use only liquid tight pvc fittings because it is outdoors and they do not want to see rust. I am beside myself and I have to address this with a honest good argument on Monday. I have faced this before the cutting corners etc. and it is driving my professionalism nuts.
K
K
