codequestion
Banned
- MD, USA
Attached pdf shows riser. In riser #1 is of ATM 1 and ATM 2 . #2 in the riser is the service disconnect. #8 is the utility pole. #5 are ground rods in the riser. #6 is grounding electrode conductor. #9 is equipment grounding conductor.
It shows service system ground electrode system connected to ATM 1 and ATM 2 and the service disconnect. The ATMs are far apart from the service disconnect. Can I do the grounding electrode system connection as shown on the diagram or does it violate NEC 2014?
